How to build RC Car with the esp8266.
At the beginning my story I would like to say, that this was my first time to IOT topic. I'm a complete beginner, but one thing I have is the desire to known new technologies.
A month ago my colleague make presentation about #esp8266 and I was impressed this small board. So I decided that I would like to known more about #esp8266 and similar stuff.
I use Micropython (http://micropython.org/download) it is a firmware for the #esp8266 boards.
At the beginning I don't underestand how it works, but I have read a lot of webpages and articles about it. The first success when I could turn on and turn off Led :) Next I bought distance sensor, temperature and humidity sensor....
Next I bought the engine but I didn't know nothing about. So I bought two engines SG90. Unfortunately turned out, that it is only the servo engine :(
Afterwards I was reading about engines and I bought two engines and motor shield (L298N)
Together with my son (7years old) we used old lego car body and double sided tape :)
In effect ?
Then we used the battery 9V to power the motor.
Putting all together:
When it comes to steering and turning sideways I used trick. For example if I wanted turn left I used left engine 30% power and right engine 80-100% power.
Next I connected red LED and two light green LED on the front of car
Everything works fine in python console.
For instance, when I wanted to run I typed ** E.forward() ** when I wanted to stop car I had to type ** E.stop(). **
Python code is on my github:
https://github.com/dgolak/esp8266/blob/master/main.py
Afterwards I wrote wifi connection to my mobile phone, simple webserwer and web application to steering a car.
To sum up.
It was a great time with my son, we made a simple car with the steering by mobile phone or any devices with the use of WIFI
source: https://github.com/dgolak/esp8266/blob/master/main.py
Twitter: http://twitter.com/dawid_golak
Wassim
Fabien-Chouteau
Rohit Gupta
That looks just great - i like the approach doint this with ESP 8266 and micropython. I will try to go this way - greetings
