I have the majority of the parts but now I have to figure out how I will be mounting everything together. I need a stable platform for the Erle Brain 3 and RPLidar so I am thinking of making mounts for them in SolidWorks and 3D printing them out. The GPS and Telemetry should be fine mounting directly to the frame with some double sided tape so I am not worried about that. The next thing I need to get in order is learning the Robot Operating System (ROS) which will be used to control the entire vehicle. Once I make some progress on the mount designs I will update this post.
Good luck getting your Ackermann based vehicle to work with the ros navigation stack. Looking forward to see the results.
