Wow it is some kind of addictive ;)
This is the latest Code:
Software serial multple serial test
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
char charbuffer[255];
int inCount;
void setup()
// Open serial communications and wait for port to open:
Serial.begin(19200);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
Serial.print("Ready for commands \r\n");
void loop() // run over and over
byte inputChar;
int iCount;
while (mySerial.available()>0)
inputChar = mySerial.read();
charbuffer[inCount] = inputChar;
// If there is a new line, there shall also be a new row
if(inputChar == '\n')
inCount++;
charbuffer[inCount] = '\r';
inCount++;
// Print if buffer is full
if(inCount > 250)
Serial.print(charbuffer);
inCount = 0;
while (inCount > 0)
inCount--;
charbuffer[inCount] = 0;
if(inCount > 0)
inCount = 0;
while (inCount > 0)
inCount--;
if (Serial.available())
switch(Serial.read())
case '?':
Serial.print("Send At...");
mySerial.print("AT+CIPSTATUS\r\n");
break;
case '1':
mySerial.print("AT+CIPSTART=\"TCP\",\"retro.hackaday.com\",80\r\n");
break;
case '2':
mySerial.print("AT+CIPSENDBUF=48\r\n");
break;
case '3':
mySerial.print("GET / HTTP/1.1\r\nHost: retro.hackaday.com:80\r\n\r\n");
break;
case '5':
mySerial.print("+IPD,100\r\n");
break;
Still not that pretty but it works more or less if you send 1,2,3,5 :-D
It seems there are still some characters missing... but it is already to late for "today".
BTW: After i increased the Baudrate of mySerial, i got less missing characters.
I think somebody who is more experienced will find this code a piece of crap. Sorry for this.
don't apologise for code that works :) I never did the actual AT command stuff, only arduino and lua.
