Greatly Inspired by #ESP8266 Retro Browser I have rewritten my sketch a bit :)
Software serial With ESP 8266 Test
Tested with Arduino Uno
Autor: Stefan-Xp @ HackADay.io
+++ ESP8266 ++
D10 --> ESP8266 TX
D11 --> ESP8266 RX
+++ Input +++
A0 --> Button --> Ground
+++ Output +++
// Status LEDs
tbd
#include <SoftwareSerial.h>
// Access Point
#define SSID "tbd"
#define PASS "0123456789" // My luggage has the same combination!
// General Defines
#define TIMEOUT 5000 // ~ms
#define SERVER_IDENTIFIER "useYourOwn;-)"
// I/O Defines
#define SWITCH_PIN A0
SoftwareSerial mySerial(10, 11); // RX, TX ; SoftwareSerial for ESP8266
char charbuffer[255]; // Characterbuffer for incoming Data
int inCount; // Count of incoming Data Bytes
boolean sendHTTPRequest(String Parameter); // Function for sendingHTTPRequest
void setup()
// Open serial communications and wait for port to open:
Serial.begin(19200);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// set the data rate for the SoftwareSerial port for ESP8266
mySerial.begin(9600); // Perhapps you need to Adjust the Baudrate at the ESP8266!
Serial.print("Ready for commands!\r\n");
// This is one Input Pin
pinMode(SWITCH_PIN, INPUT_PULLUP);
void loop() // run over and over
byte inputChar, rndCount;
String OutPutParameter;
int iCount;
/* Maybe there should be regular checks if the ESP8266 is still
connected or something...
// This reads the Data as long as there are some available
while (mySerial.available()>0)
inputChar = mySerial.read();
charbuffer[inCount] = inputChar;
// If there is a new line, there shall also be a new row
if(inputChar == '\n')
inCount++;
charbuffer[inCount] = '\r';
inCount++;
// Print if buffer is full
if(inCount > 254)
Serial.print(charbuffer);
inCount = 0;
while (inCount > 0)
// clear buffer
inCount--;
charbuffer[inCount] = 0;
// If there are some Datas in the Buffer, print them now.
if(inCount > 0)
inCount = 0;
while (inCount > 0)
// clear buffer
inCount--;
// If there are commands via Serial...
if (Serial.available())
switch(Serial.read())
case '?':
Serial.print("Request Status ... ");
mySerial.print("AT+CIPSTATUS\r\n");
break;
case 's': // Send Testdata
OutPutParameter = "/ESP_Test/Test.php?info=RandomNumber%20";
OutPutParameter += random(1000);
OutPutParameter += "<br>";
sendHTTPRequest(OutPutParameter);
// If Button is pressed, send on release..
if(digitalRead(SWITCH_PIN) == LOW)
while(digitalRead(SWITCH_PIN) == LOW)
rndCount++;
OutPutParameter = "/ESP_Test/Test.php?info=RandomNumber%20by%20Button:%20";
OutPutParameter += rndCount;
// This Function waits as long as the desired String is received
boolean waitForString(String myString)
int TimeOut = 0;
byte checkNumber = 0;
Serial.print("Waiting for String " + myString + " ... ");
// Do this until TimeOut
while (TimeOut < TIMEOUT)
if(mySerial.available()>0)
// Check every Character of myString
if(mySerial.read() == myString[checkNumber])
checkNumber++;
if(checkNumber >= myString.length())
// Pass - ALL Characters were found
return true;
else
delay(1);
TimeOut++;
return false;
// This function sends a HTTP Request with specific parameters
Serial.println("Sending HTTP Request...");
String cmd, cmd2;
// Contact the Server
cmd = "AT+CIPSTART=\"TCP\",\"";
cmd += SERVER_IDENTIFIER;
cmd += "\",80\r\n";
mySerial.print(cmd);
delay(100);
// Check if "ok"
if(waitForString("ok") == false)
return false;
else
Serial.println("pass");
// Build Command to be sent to the Server
cmd = "GET ";
cmd += Parameter + " HTTP/1.1\r\nHost: ";
cmd += ":80\r\n\r\n";
// Tell the ESP8266 to listen to Data
cmd2 = "AT+CIPSENDBUF=";
cmd2 += cmd.length() ;
cmd2 += "\r\n";
mySerial.print(cmd2);
// Now wait for >
if(waitForString(">") == false)
return false;
else
// Send Request
// Maybe a check should be here to check if the Data was transfered sucessfully.
// Connect to the specified wireless network.
// To do: Implement a StatusLED for Connection State.
// To do: Test This.
boolean connectWiFi()
Serial.print("WifiNetwork Connect ... ");
String cmd = "AT+CWJAP=\"";
cmd += SSID;
cmd += "\",\"";
cmd += PASS;
cmd += "\"";
// Check if "ok"
Serial.println(" fail");
return false;
else
Serial.println(" pass");
return true;
The Code is a bit bigger now... i think nothing for the 1k Contest :-P
And here is the Code in the PHP Page:
<?php
$inhalt = $_GET['info'] . "\n\r";
$handle = fopen ("Result.html", a); // Attach
fwrite ($handle, $inhalt);
fclose ($handle);
echo "Write: " . $inhalt . "Success"
And also the Result.htm:
RandomNumber 807<br>
RandomNumber 249<br>
RandomNumber by Button: 208<br>
RandomNumber by Button: 73<br>
RandomNumber by Button: 2<br>
RandomNumber by Button: 99<br>
RandomNumber 73<br>
Did you notice, that you get the same Random Numbers every Time the Arduino reboots? :-DThe next steps are:
- Adding at least 2 Status LEDs (Connection State, Request State)
- Exchanging Softwareserial for Serial
- Add the SoftwareSerial for the BOSS Swissphone Pager
- Check the Webinterface of http://www.Divera247.com
- Develop an Algorithm to Get a Useful AlertMessage.
- Solder together an Hardware incarnation of this Device ;-)
I hope you enjoyed this writeup and comments are always apreciated!
Ahh and also need to lock the Request in case it is not completed...
