Our article on the microfluidics control system has just been published in HardwareX! Check it out here: https://www.sciencedirect.com/science/article/pii/S2468067218301147
There have been a few updates since the last logs here: mainly an updated PCB, a proper enclosure, and some software updates.
The article contains all the details including build instructions, operation instructions, and links to all the design files and code necessary to replicate the build.
