While thinking about this little project there might happend some featurecreep. But i will put all the Ideas for this little Gadget into the wild, so other will maybe give tipps for even more features.
- Hardware
- Output
- Display
- LCD or OLED
- eInk (maybe as backpack for showing pager information)
- LED
- Vibration Motor
- page like functionality
- Display
- Input
- Blackberry Q10 Keyboard
- maybe a stm8 based keyboard controller to not use up all the main MCU pins
- NFC Tag Reader/Write
- Buttons
- Rotary Encoder
- Other
- Realtime Clock
- Main CPU/MCU
- ESP8266
- not enough pins?
- ESP32
- could be main MCU or also just wifi coprocessor
- STM32
- no build in WiFi
- could try to code in rust-lang
- ESP8266
- Output
- Batteries
- would love to have 2 to 3 days of usage
- Charger via (micro)USB(-C)
- 18650 (Between 1 and 3)
- Storage
- SD/microSD
- create eeprom cartridges?
- need to find a small/cheap pcb edge connector for this
- Connectivity
- WiFi
- ESP8266/ESP32
- LoRa(like)
- 433MHz
- Protocolls
- CoAP?
- IKEA Lamps
- MQTT (read/send)
- CalDAV
- NTP (sync the realtime clock)
- CoAP?
- WiFi
- Apps
- Writing/Notetaking
- Sync via WiFi to Nextcloud?!
- Calendar
- Clock
- Pager
- MQTT based?
- Send in 433MHz spectrum?
- maybe encrypted
- Maybe more via gameboy like cartridges or bin files from sd card
WooDWorkeR
So, what about software? I'm actually writing a worklog right now about the software side of "personal information managers", so I wish this project expanded on this, too =)
since i want to have wifi, i would love to have owncloud sync for notes and calendar.
AND i need to find out how to get random bin files loaded as executables so i can load apps from a sd card
ouh, tell me when you find stuff about the last one, I need that (although for the ESP8266)
I'm missing one important item in this list: size and weight. It's good idea to consider this at the beginning, as it may interfere with some other items. Also, it may help to cool down the feature creep.
so there is the keyboard + the (most probbably 3.2 inch) display and the 1-3 batteries determing size and wheight
maximum size would be PocketCHIP size
