Hackaday.io Hackaday.io
Sign up Log in
Solar Tracker - Prototype/Proof of Concept
Simple pan and tilt mechanism for sun tracking solar cells.
paul-crouchPaul Crouch
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
7 followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
636
2
7
10
Team (1)
  • paul-crouchPaul Crouch
Join this project's team
  • Robot 7
shelved project
Software
solar tracker prototype rc servo arduino
This project was created on 09/29/2017 and last updated 6 years ago.
Description
Ultimately intended for use on a robot, this hack was just to see what was involved in getting articulated solar panels to face the brightest point in the sky (or room).
Using four small LDRs, an Arduino compares the light intensity in both the vertical and horizontal axis, then moves two small RC servos in a cheap plastic pan-tilt mechanism to face it. Solar panels would be fixed to it or independently articulated.
Mechanical structure will be reconstructed to suit the robot. I will update this project page as/when appropriate. Shelved until I'm ready.
Details
Components
  • 1 × Servo Pan/Tilt kit https://www.aliexpress.com/item/PT-Pan-Tilt-Camera-Platform-Anti-Vibration-Camera-Mount-for-Aircraft-FPV/32532784948.html?spm=2114.search0304.4.19.kdo15l
  • 4 × LDRs ...and 4x resistors to form potential dividers for Arduino analogue inputs.
  • 1 × Your favourite Arduino I used an Uno, just because it's what I had.
Log In/Sign up to comment
Sign up with Github
OR
Paul Crouch wrote 10/01/2017 at 10:11 • point
It does have that quality to it doesn’t it? :-)
Morning.Star wrote 10/01/2017 at 09:33 • point
Muahahah... Its.... ALIVE!! XD
The 2017 Hackaday Prize
SOLARIS-1 IS AN AUTONOMOUS AND ENERGY INDEPENDENT ROBOT TO CLEAN LARGE SOLAR ARRAYS AND MAINTAIN ITS MAX EFFICIENCY EVERY DAY .
Project Owner Contributor
INCREASING SOLAR EFFICIENCY
aryaman-bansalaryaman bansal
explore the intersection of renewable energy and electronics, and take a significant step towards sustainable living with our comprehensive
Solar Tracker Using Arduino
electronicsworkshopselectronicsworkshops
Incorporate solar trackers in Microgrids to increase energy production.
Solar Trackers for Microgrids
pranit-nadipelliPranit Nadipelli
The 2016 Hackaday Prize
The MAKER Knight Rider robot: solar powered, voice controlled, android app controlled
s0lrider
danielDaniel
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Solar Tracker - Prototype/Proof of Concept", please tell us the reason.
Send message
Remove Member
