The connection between human and machine should be as simple as possible
With this project it is possible to simply transfer a scanned line to the human being, the most important part of this project is to transfer only the line and thereby keep the interface human-actuators as simple as possible.
By vibrating motors, this so-called line is projected onto the skin surface, so the person can imagine the environment.
The scanner is attached to the head so that the entire environment can be imaged by moving the head
Simple and cheap to build
It works quite well, only the software implementation would still have to be worked
Unfortunately, I have too little experience with programming
it would be nice if this project became a usable tool !!!
