Our test reflow on the connector resulted in some toasty plastic. We are still learning how to use our new reflow oven, so this should be solvable with a little experimentation.
A project log for 4P-RGB-Strip Flex Module
A Flex Module 4 pin connector that supports RGB strips with 4 leads (as well as many other 1 or 2 pin I/O peripherals). For sale on Tindie.
