I stopped believing that I am somehow competent enough to order the right footprint of the chips, and I decided to simply redesign the PCB to accommodate the bigger chips. When life gives you lemons...
It just barely fits, together with the pullups and a filter cap. I had to move the address jumpers to the bottom, though:
Now working on fitting as many as I can on a 10x10cm board:
