If you don't need or want a simple C driver for this chipset, I'd skip this post!
#define OE LATBbits.LATB5
#define XLAT LATCbits.LATC2
//12 bits per channel = 1.5 bytes * 24 channels
#define TABLESIZE 36
#define CHANNELS 24
void main(void)
unsigned int i;
uint8_t mapInc = 0;
uint8_t blob[TABLESIZE];
while(1)
//Zero out buffer
for(i = 0; i < TABLESIZE; i++) {
blob[i] = 0x00;
//Colourspace is 0xFFF levels
//Dividing/multiplying by four to speed up the fade
for(i = 0; i < 0x1000 / 4; i++) {
setChannel(blob, mapInc, i * 4);
LEDMap(blob);
mapInc = (mapInc + 1) % 24;
void setChannel(uint8_t *blob, uint8_t channel, uint16_t value) {
uint8_t lvalue;
uint8_t rvalue;
uint8_t newVal;
uint8_t byteAddr;
if(channel % 2 == 0) {
byteAddr = (channel * 3) / 2;
lvalue = (uint8_t)(value & 0xFF);
rvalue = (uint8_t)(value >> 8);
*(blob + byteAddr) = lvalue;
newVal = (*(blob + byteAddr + 1)) & 0xF0;
newVal = rvalue | newVal;
*(blob + byteAddr + 1) = newVal;
} else {
byteAddr = (((channel - 1) * 3) / 2) + 1;
lvalue = (uint8_t)(value << 4) & 0xF0;
rvalue = (uint8_t)(value >> 4);
newVal = (*(blob + byteAddr)) & 0x0F;
newVal = lvalue | newVal;
*(blob + byteAddr) = newVal;
*(blob + byteAddr + 1) = rvalue;
void LEDMap(uint8_t *blob)
uint8_t data = 0;
XLAT = 0;
for(int i = TABLESIZE - 1; i >= 0; i--) {
data = *(blob + i);
SPIWrite(data);
XLAT = 1;
__delay_ms(1);
XLAT = 0;
I cut out all the PIC initialisation stuff, but the only gotcha there is that the SPI must transmit on the active to idle clock transition.
