We decided to create a python Jupyter Notebook (based on brandoncurtis gist) so that is very easy for students to play with params and see in a matplotlib graph what is happening with the signal coming from telescope in realtime mode
- Setup: import used libraries, setup for usb serial and matplotlib config
- Algorithm: from esp32 serial output on tty write sun data to a file and plot graph
