Redesigned to drop the voltage regulator and use 3 to 6 volts. Note that you can't 4 AA's as that will exceed ATTiny specs as they each start closer to 1.8v.... so 3 AA's it is!
I designed and ordered via OshPark will continue when they arrive.
