First you have to download and write the Rasbian image to an SD card, i recommend to download the Raspbian Lite but if you want to connect to a WiFi with captive portal (like a hotel WiFi) you can download the Desktop version. THIS PROJECT IS DONE ON RASPBIAN JESSIE LITE
You can download the image you prefer from official Raspberry Pi site:
https://www.raspberrypi.org/downloads/raspbian/
Ones you download the image you can follow the instructions to write the img to your SD card:
https://www.raspberrypi.org/documentation/installation/installing-images/README.md
Tip for those who want a full headless build so you dont want to have a keyboard or monitor:
After you write the image you should see a boot partition on My Computer
so to automatically your Pi connect to your WiFi network you have to make a new file named "wpa_supplicant.conf" with (Notepad++ or similar program) and put the following code inside and change it to your needs :
country="Your country 2 letter code here" (eg. GR,US) ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1 network={ ssid="YOURSSID" psk="YOURPASS" key_mgmt=WPA-PSK }
Like this:
More info here : https://www.raspberrypi.org/documentation/configuration/wireless/wireless-cli.md
Also to enable ssh headless you need to create a blank file called "ssh" also in the boot partition (name it just ssh, maybe ssh.txt works i dont know leave a comment if it does) if you dont have show hidden files enabled you can create it with cmd :
Run cmd and type this command "echo>D:/ssh" (replace the D:/ with your SD path for me is D:/)
Now you are ready to power on your Pi. Just insert the SD card you just prepared and give it power. Give Pi 30-40 seconds to boot up you can connect through your favorite SSH program i use Putty, and type at Hostname filed "raspberrypi.local" and click Open.
If you get this error:
you dont have Apple Bonjour installed so you can either download it or you have to find the Pi IP manually. So you can login to your router and go to Connected Devices or ARP table and find the IP or you can use a Network Scan tool (like Angry IP Scanner).
Now that you have the IP of the Raspberry you can connect and start the installation of the required packages.
STEP 1: update your Raspbian and install the packages that we need by typing:
sudo apt-get update sudo apt-get upgrade -y sudo apt-get install dnsmasq iptables-persistent -y
STEP 2: Find the name of your Ethernet interface with ifconfig command (in my case eth0)
STEP 3: Disable the dhcpcd for the eth0 interface by editing the /etc/dhcpcd.conf with your favorite editor (i use nano)
sudo nano /etc/dhcpcd.conf
and adding the following line at the very bottom
denyinterfaces eth0
save and exit ( Press ctrl + o to save and ctrl +x to exit )
STEP 4:
Edit the /etc/network/interfaces file by typing :
sudo nano /etc/network/interfaces
if it has any line that contains eth0 (or you interface name) comment it out by adding a # to the start of the line
add the following to the bottom:
auto eth0 allow-hotplug eth0 iface eth0 inet static address 192.168.2.1 netmask 255.255.255.0 network 192.168.2.0 broadcast 192.168.2.255
You can change the network settings as you want but you have to remember your changes for the dhcp server config later or you can leave it as it is
Optional:
if you want to use an external Wireless adapter you have to comment out the wpa_conf line
For external Wireless adapter add also the following at the bottom:
allow-hotplug wlan1 iface wlan1 inet manual wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
As the wlan1 being your wifi card name you see from ifconfig command early
again save and exit the file
STEP 5: Configure the DHCP service:
First we need to do a backup to the configuration file
sudo mv /etc/dnsmasq.conf /etc/dnsmasq.conf.bak
then edit the file
sudo nano /etc/dnsmasq.conf
and add this code
interface=eth0 listen-address=192.168.2.1 dhcp-range=192.168.2.10,192.168.2.100,12h server=8.8.8.8 bind-interfaces domain-needed bogus-priv
Now if you change the if earler in the /etc/network/interfaces you need also to change it in these file.
I let the user to decide if he wants to use the ad-blocking dns server that we setup later if you dont want that you can change the 8.8.8.8 (Google DNS) with the 192.168.2.1 (the eth0 ip) or your preferred DNS. In my case in order the client to use the ad-blocking DNS must set a static DNS to the device that uses.
STEP 6: Configure internet sharing:
First setup ipv4 forwarding by editing the file
sudo nano /etc/sysctl.conf
find and uncomment this line by removing #
net.ipv4.ip_forward=1
To activate the changes you need to run:
sudo sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward"
We also need to reset the IP table so we need to make a script to do that. Create a file named iptablereset.sh
sudo nano iptablereset.sh
and add the following:
#!/bin/sh echo "Resetting the IP Tables" ipt="/sbin/iptables" ## Failsafe - die if /sbin/iptables not found [ ! -x "$ipt" ] && { echo "$0: \"${ipt}\" command not found."; exit 1; } $ipt -P INPUT ACCEPT $ipt -P FORWARD ACCEPT $ipt -P OUTPUT ACCEPT $ipt -F $ipt -X $ipt -t nat -F $ipt -t nat -X $ipt -t mangle -F $ipt -t mangle -X $ipt -t raw -F $ipt -t raw -X
Save and exit
We need to give the script executable permissions so we run:
sudo chmod +x iptablereset.sh
And then run it :
sudo ./iptablereset.sh
Also run the following to set the firewall rules (remember to change the wlan0 and the eth0 with your interface name you see in ifconfig):
sudo iptables -t nat -A POSTROUTING -o wlan0 -j MASQUERADE sudo iptables -A FORWARD -i wlan0 -o eth0 -m state --state RELATED,ESTABLISHED -j ACCEPT sudo iptables -A FORWARD -i eth0 -o wlan0 -j ACCEPT
To save the rules we added run:
sudo sh -c "iptables-save > /etc/iptables.ipv4.nat"
We need this command to run on every boot so we edit the /etc/rc.local file:
sudo nano /etc/rc.local
Add this code before "exit 0"
iptables-restore < /etc/iptables.ipv4.nat
Thats all it for the basic part. Now you can use it but there is no ad-blocking yet.
To connect your old router with the raspberry you need an ethernet cable and you just connect the raspberry on any port you want but first :
To use it with a router you need to consider these 2 important things
- You need to change your router IP address to a different ip address from the eth0 interface (In my case the eth0 has 192.168.2.1 and my router has 192.168.2.2)
2. You need to disable the DHCP on your router because we already setup one on the raspberry
Also if your router has bridge option select it. (optional)
STEP 7 (Optional): Install Pi-Hole:
To install Pi-Hole you need to run a single command
curl -sSL https://install.pi-hole.net | bash
if you have any problem visit https://pi-hole.net/
IMPORTANT:
Continue the GUI install until you get to this screen:
You need to press NO, then Change the ip to you eth0 ip (In my case 192.168.2.1)
Also chage the gateway if needed:
If the changes are OK click Yes and continue the GUI installer:
When you finish you should see something like this :
So restart as the installer says and ones it boots you can navigate to http://192.168.2.1/admin/ (if you make changes replace the ip with yours)
from here you can see statistics, block domains, whitelist and many more. Just go to https://pi-hole.net/and learn everything that does.
Congrats you now sharing the internet from WiFi to Your old router via ethernet using raspberry and if you install Pi-Hole you also blocking ads.
