Condensation Issues
A project log for SuperVide
A Sous Vide immersion circulator that's also so much more! Heat, cool, and flash-freeze all with one inexpensive easy to build appliance.
carlCarl • 08/21/2014 at 04:29•0 Comments
Peltier modules operate by creating a temperature differential, which means if we're using them to heat our water the other side will get cold.  Really cold.  When we warm it using a heatsink and fan we're going to get condensation.
Due to this consideration the heatsinks used are straight-finned aluminum, with a drip tray integrated underneath.  A small tube then runs to a bottle so condensation can be safely removed.  A simple liquid sensor at the top of the bottle will power down the SuperVide in case of overflow.
