tapMatrix: How I Quit Hating Alarm Clocks and Learned to Build My Own. A hobby. An idea. An obsession. A quest. An open hardware experiment. I started the Open Clock Project in 2012 with some crazy ideas on a Tumblr: http://clock.bonsignore.com ... I built a prototype, then another, then took it to Maker Faire, then to Shanghai and Shenzhen, and then back to Maker Faire. Now I'm learning KiCad and designing a Arduino shield to make an affordable kit. And I'm writing a smartphone app to communicate with the next generation connected Clock from afar.
Previously, I've built this project using an Arduino UNO + Adafruit Wave Shield + Macetech Chronodot + Sure Electronics 16x32 bicolor LED matrix + Fujitsu 4-wire resistive touchscreen.
Current goal: Smash the Wave Shield and Chronodot components into one Arduino-compatible shield, along with the connectors for the LED matrix and touchscreen.
Status: I've tried to translate the thru-hole Wave Shield components into their SMD equivalents, reroute created a schematic in KiCad, did a 2-layer board layout, OSH-Park'ed the board, assembled the components, and found three footprint snafus. So I've revised the schematic and BOM, and I'm working on the revised layout. Before I go crazy, this would be a good time for a peer review...
The BOM and Schematic are on a Google spreadsheet here:
Any comments or suggestions will be greatly appreciated! Especially for:
- the large capacitors (C4/C6C9) - would SMD aluminum cans be better?
- the LDO 3.3V regulator (U1) - not sure if this is a good choice, or if I need to worry about heat, or something else that I'm not thinking about.
- the opamp (U4) - I was guessing here, hope this is reasonable.
Finally, my torn-up layout this pictured below... Before I rearrange and reroute things, if there's anything else that I should think about, now would be a good time.
* LED matrices will be modular, so they can be reused in other projects. The BoM cost for one 8x8 module with backpack would be under €2 (in quantities <10).
* STM32 BluePill instead of AVR. The STM32 has a built in RTC, can be debugged in circuit, is faster, cheaper (€1.62), has more memory...
* Sunrise simulation would be nice. It's the only good feature on my current Philips clock. That's the only reason I have for not throwing away that clock. A 3W RGB LED would suffice.
* I want to add AA-alkaline cell with MCP1640 booster for backup. These AAs have a lot more energy and are much cheaper than CR2032. When there's a power brownout, I still want to be woken in the morning. A CR2032 might not be able to sound the alarm loud enough.
* Network connectivity would be left out as senior citizens would have trouble to set that up.
* I would make it possible to set different alarm times for every day of the week.
Your question about SMD elcos : these are generally more expensive than radial through hole ones. You have through hole components already. So for PBA manufacturing it won't add much to the cost.
This is fantastic! My efforts have gone into hibernation in the last few years, as other aspects of life have kept my quite busy... Hoping to pick up this thread again in the not too distant future, and I look forward to incorporating the improvements you have suggested! Thanks for sharing.
This is awesome! I love the way you're using a touch screen with an LED matrix. props on taking several open source designs and mashing them up into the perfect solution for your problem!
Hi Craig,
Your clock inspired me to start my own project (https://hackaday.io/project/93650-better-alarm-clock/). I'll only roughly base myself on your design. I want to make it very cheap and modular.
