Update:
- Tested the LED Dot Matrix Display.
- Test AVRDude to burn sample hex files.
- Installed drivers for USB ASP Programmer.
- Tested the user inputs.
- Designed a layout for the connections.
- Partially designed the simulation in Proteus.
To Implement :
- Implement the game code.
- Final launch, run and improvisations.
