Hackaday.io Hackaday.io
Sign up Log in
SMT Part Tape Counter
Pull the tape through a slot and get the # of parts on a 7-seg display.
owen-truebloodOwen Trueblood
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
11 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
712
2
11
9
Team (1)
  • owen-truebloodOwen Trueblood
Join this project's team
completed project
TOOL
This project was created on 10/29/2017 and last updated 5 years ago.
Description
In order to get a handle on my DigiKey SMT part cruft without counting parts one by one I built this simple tool to count parts in SMT reels. It's a simple 3D-printed sensor block with a break-beam sensor that I can easily slide the SMT part tape through which is hooked up to a simple Arduino shield with two buttons and a 3 digit 7-seg display for displaying the parts count. The right button resets the count and the left button sets the number of parts per hole on the tape.
I was lazy hooking up the 7-segs and put a current-limiting resistor per digit on the low-side, so the brightness changes depending on how many segments are lit up. Still legible and saved me having to add MOSFETs or something to sink the current.
Files
SMD_part_counter_breakbeam_holder.stl
3D-printable breakbeam holder. Was made specifically for a part I found in my junk drawer so YMMV.
Standard Tesselated Geometry - 6.33 kB - 11/11/2017 at 19:52
Download
Project Logs
Collapse
  • Demo & Code
    Owen Trueblood • 10/29/2017 at 01:35 • 0 comments
    Code: https://gist.github.com/jmptable/e9cdc0f8b6af5c13d749528b5c016199
View project log
Log In/Sign up to comment
Sign up with Github
OR
Arya wrote 11/10/2017 at 23:24 • point
Hi! Do you have an .STL of the 3D printed adapter, by any chance?
Owen Trueblood wrote 11/11/2017 at 19:54 • point
Hello! Yeah, I've attached one as a file to the project. But it was designed for a part that I found in my junk drawer so it may not be reusable.
The 2016 Hackaday Prize
motorcycle made smart with Atmega, hall effect sensor and OLED
Project Owner Contributor
SMARTDAX
tedTed
TTGO T-Display based magnetic field strength meter
Magnetometer / Gaussmeter / Teslameter
andy-pughAndy Pugh
Rank the talk you have just attended at a conference, by pressing one of the three buttons.
Talk Ranking Machine
dehipudeʃhipu
Supplyframe DesignLab: 2022 Hackada…
Incredibly simple but functional Weather Station
DIY Simple BME280 Arduino Weather Station
mircemkmircemk
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "SMT Part Tape Counter", please tell us the reason.
Send message
Remove Member
