Device should be down only if the internet is down. If sensor causing problems script continuously reset ESP8266 board until a sensor is fixed. The script should handle problematic sensor and continue to update other sensors. Picture show downtime before handling problems. Each time when sensor fali Blynk update terminal with name of fault sensor and time of fail.
