I am working on the sensor placing, but I have a problem with thermal dissapation from the display and the mega, so I can not place the HTU21 sensor too close to the casing, because it will measuring higher themperature then it shoud have to.
The other which I am thinking of what I really like to see in the menu. I figured out, I will need 6 button or menu lap for the main menu, which will be:
- Time
- Graphs
- Web
- Setting themperature limit
- Paint / note, because I would like to leave messages on the screen if it needed.
- A Back button to return to the main screen. It will be the screen where you can see temp and humidity.
Some more picture:
I already have an lowe level menu, where I can go to the menu selector and back to the main screen.
I will write about the status of the project soon again.
I am glad that you have shared this post. Many people face a lot of issues regarding sensors and the reason is probably that they don’t think indicatively and now I'm able to check https://my-assignment.help/cheap-assignment-help-australia/ to get best assignment services. By your post one gets a lot of new ideas for resolving their minor issues.
