Repeat the session
A project log for Atix: Language learning audio based device
Learn and practice words from a foreign language with a completely audio based device. Select the correct answers and keep rolling!
hernn-valdsHernán Valdés • 11/09/2017 at 13:29•0 Comments
Yesterday I tested and used the device in my whole travel to University. It was very unpleasant that after every round I need to select from the beginning the option to keep exercising, so I added now the option to select if you want to repeat the session after you completed the 5 words round. It asks you and Left movement with the Joystick is "Yes" and with the right is "No" (everything with audio).
I am want to keep doing only Software changes, to prove if only 1 joystick (with a push button in it) is enough for an Interface.
I want to add:
  1. General audio instructions that you can hear every time (How to use it)
  2. Categories (Computer science vocabulary English --> German)
  3. New algorithm to select the random words to learn
  4. Repeat the word in English
