I've decided to experiment with the ESP32's RMT controller for generating step pulses.
The technique has already been explored over at buildlog.net blog and it looks really promising. I want to see if this will be a practical method for precision step pulse control in MicroPython. I'll write more about this once I've gotten MicroPython on the ESP32 Wrover to control these shiny new gecko drives.
Mukunda Modell
I still plan to use the BeagleBone as well. I really just want to play with generating step pulses from the ESP32's RMT device, for the fun and challenge of it, and to see if I can make such a tiny chip run steppers from a high level language like python.
The RMT device should allow me to ignore any interrupt handler latency that micropython adds due to running interpreted code on a microcontroller. The ESP32's RMT is a hardware buffered pulse generator which was designed for encoding / decoding infrared remote control pulses but it can bang out a sequence of queued commands without software micromanaging the communication - just what I need for real-time control. In many ways it's similar to using PRUs for step pulse generation.
Anyway I think it'll be really cool to interact with the machine via a remote micropython shell running on a $10 chip. I'm sure the BeagleBone is a lot more practical though and I'm going to check out BeagleG right now.
@Dean Gouramanis Is there any trick to getting the optocape running with BeagleG?
