This week we have been working to print and test a peristaltic pump design. First, we printed a miniature version which has a 53mm diameter to test the gears. The second version that we printed is about a 93mm diameter and we tested it with a screw driver and some tubing to see if it moves water. Peep the video below to see the result!
