Drone Autopilot with Raspberry Pi CM3 .
Pixhawk Flight Control Unit based autopilot with Raspberry Pi Computer Module 3 and all other requied sensors, modules built-in.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
As a DIY drone developer i found current drone development kit too complex and too messy with cables. I decided to make a Pixhawk Cube based Autopilot with all the required sensors built-in and I added Raspberry Pi Computer module 3 as compoanion computer to make it easy to run code inside RPI in the air . It has Ublox M8N GPS module, Microhard telemetry module, Airspeed sensor , and RPI CM3. Also it has CSi camera port and many GPIO pins from RPI and from Cube to make hardware conection easier. for more info check https://dron.ee/
Rich text editor
