Testing of the preliminary switchmode converter worked well, but after braking too hard while going too fast, the plastic sprocket shattered. Probably because the M4 screw bent, but I think it needs a metal sprocket instead. Unfortunantly the only metal sprocket for this type of chain I have is the one already on the bike's wheel, so I needed to drill one out on the drillpress and round it off with the dremel.
After many hours of tedious drilling and grinding, the sprocket is finished. It works well.
recyclojunk
