Here is the new control panel that addresses some of the shortcomings mentioned previously:
![](https://cdn.hackaday.io/images/9178111535143024017.jpeg)
It is longer and mounted higher up to make it better reachable, it includes a connector for a foot switch to complement the trigger button, and it features some more knobs to play with: A potentiometer to adjust the red/green choice to the ambient lighting (or just modify it artificially), and two push buttons that exchange the colors in the final image, to give a preview of what it will look like when plotted with different pens. These also light up in the chosen colors. To achieve this, I ripped out their original white LEDs and instead illuminate them from the side with a two-LED piece of NeoPixel strip.
The additional space also allows mounting the Arduino board and the 5V power supply beneath the panel, which reduces the clutter inside the pyramid.
![](https://cdn.hackaday.io/images/1762521535143044105.jpeg)
It is all wired up and the Arduino software written, now I just need to make use of it in the image processing application.
