I was alble to salvage two stepper controllers which are fairly easy interface to, since i have 2 steppers i'll be using these to move the y and z axes, i won't be step counting for position though, i prefer to use encoders to determine position.
A project log for Closed-loop control CNC Electrochemical Machining
A controllable power supply and gantry mill for Electrochemical and Electric discharge machining.
