I've arrived at early check-in to get the camera badge and start working. I'm apparently not the only one with this idea: the work tables are already full by the time I arrived. Time to find a corner of the room to set up shop on the floor.
Here's the first test using the camera badge on the panning base I've already built. Since I haven't written the time-lapse video capture code yet, this is a real-time video shot using the video recording mode already on the badge.
