Bill of material:
- a 240x190x90mm waterproof junction box.
- Shielded CAT6A cable
- Phone twisted pair, or any other source of single AWG22-20 wire.
- Panel XLR connectors, any multiple of 4, male or female, you can also mix them as needed. any brand is good, i used Richtech.
- D mount keystone adapter, 1 every 4 XLR.
- Cat6a keystone RJ45 female jack, 1 every 4 XLR, i used Linkway's.
- Cat6a RJ45 plugs and rubber boots.
- Tubing for wrapping ethernet pairs, i used Medical IV tubing.
- M3 screws and nuts.
- Lots of heat shrink tubing.
Brian
Gertlex
Christoph Tack
Adam Gulyas
did this work? and what was its interface digitally? is it possible to output it to another junction box to serve as an analog xlr snake?
