Unfortunately the core51822 modules use a 2.00mm (0.787") pitch rather than regular breadboard 0.1" (2.54mm). It's double row (2x9 pin) as well which makes DIY adapters more difficult.
There are a couple solution.
- buy an Waveshare BLE400 breakout board ($9)
- soldering wires to the headers / replacing the headers ($0)
- modding a pre-existing adapter ($?)
- make an adapter on perfboard (sub $2)
- get a PCB made like this or this
- 44-pin (laptop) ATA cable ($1 from China, $6 from US after shipping)
- 2x10 pin 2mm pitch IDC cable ($4)
- 2x20 pin 2mm pitch headers only (10pk $4) and make your own cable
- buy 2.00mm to 0.1" jumper cables ($5-7)
edit: after using it for a few days my 0.1" jumpers have failed. Scratch that method. I've instead swapped some headers with an inch of 24 AWG wire. More attempts to come later.
Maave
Hi, old post but I got a few boards made up for a remote control project- uses a standard 2mm pitch connect from RS ( https://uk.rs-online.com/web/p/pcb-sockets/7644648/ ) components. If you're in the UK I can post at cost- details https://peter.windridge.org.uk/home/bike-handlebar-bluetooth-remote-control-for-phone-navigation-and-music . Might be suitable for game pad with some bodging.
