This control system is designed run on its own but also make use of the facilities a connected device affords us.
The control unit will be just a box with a few outlets for pumps etc. No buttons, no display. All the feedback and adjustments will be done by a mobile phone interface and for this project Ive chosen to work with the Blynk system.
In a nut shell Blynk allows you to pass data between the Blynk App and your connected device.
Requirements
- Display
- Temperature
- Humidity
- Moisture Level
- Adjust
- Fan set point
- Mister set point
- Water pump set point
Ive put together a Blynk App to get the ball rolling and looks something like this
The Temp, Humidity and Moisture level will be displayed across the top of the screen the sliders below those will adjust the set point for each parameter.
The LED at the bottom is a warning indicator that the water resivior is low.
The Graph at this stage will display moisture level of the bed over time.
