Today the project starts in earnest. I was contacted last night by my brother with a rather disturbing picture of dead plants.
Due to the unattended operation some failure occurred and with no monitoring of the system the grow bed was devoid of water for a period of time.
While contemplating the requirements of the project all manner of ideas have come up and what we could control and needless to say feature creep was starting to set in so a decision has been made to lock down the parameters just as indicated in the description above and save the added features for a future project and upgrade once we had the opportunity to try the system out. Implementing great ideas that may be not necessary will only delay the project further which will lead to greater crop loss.
The project in its current form will be limited to 3 inputs and 3 outputs
Inputs
| Node MCU Pin | Description | Type |
| A0 | Grow media Moisture | Analog |
| D1 | Water Storage Level | Digital |
| D2 | Temperature and Humidity | One wire Bus |
Outputs
| D5 | Water Pump | Digital |
| D6 | Exhaust Fan | Digital |
| D7 | Mister | Digital |
| D8 | Moisture Sense Activate | Digital |
Specs for the NODE MCU 1.0 Board available from
https://github.com/nodemcu/nodemcu-devkit-v1.0
Pinouts
Saabman
