Now I have the IO sorted out time to move onto making the firmware come together.
The basic frame work.
Read All the sensor values -
- Grow Bed moisture level (Moisture)
- Temperature (Temp)
- Humidity (Humid)
- Water level (WaterLevel)
Send Values to Blynk App.
If Moisture is low - Turn on the Pump for 6 minutes (the length of time it takes to flood the bed)
If Temp is above X level - Turn on fans
If Humid is below Y level - Turn on mister for 1 minute (this is an arbitrary value and will need tuning)
If WaterLevel is low - Set an Alert on the Blynk App.
Set points to be adjusted by Blynk
Temperature and Humidity readings displayed on the Blynk App
Saabman
