Nutrient Film (NF) Technique hydroponics system you can build up and leave unattended
Connectivity schematics for the electronics (with device codes from the process schematic) below. "UDOO" is a tiny PC with embedded arduino due, although I'll be using a separate due board. "Volt. div." is a voltage divider circuit for matching the sensor output to the ADC voltage limits, and "Instr. amp." is an instrumentation amplifier. "Q1"--"Q9" refer to switches, most likely power MOSFETs. Dashed line shows the individual boards; I'll place the pressure sensors (i.e. water level sensors) on the board in order to have the amplification as close to the sensors as possible. I'll make the final schematic with eagle once I've chosen the components. Next-up: Software
The process schematic of the NF system is shown below. This is the general plan, I'll go through every detail in later logs.
Cool project man! I'm doing pretty much the same thing!
https://hackaday.io/project/2964-hydropwnics
I do plan to keep working when the competition is over!
Has this been finished yet?
