Mass production
A project log for Minecraft server display ver 2
Updated standalone project to show the numbers of players on a Minecraft server without booting a computer
amli2011Amli2011 • 12/29/2017 at 09:19•0 Comments
Or not. But I have printed the second unit in one week.
Now i have one finished showing the status of our ARK server. I took the electronics from the old card box version and used it in this unit.
And the one I have printed now will show the status of our minecraft server. I will for this one design a pcb and document the electronics better along the process.
The project files are updated in the files section.
software now haves a #define MINECRAFT to switch between minecraft and steam server mode at compile time.
At startup the software also will do a full sweep with the needle. First a stop at the "err" marking, then a stop at "0" , then going to "F" or full and sweeping back to "0". if button on GPIO0 is pressed during this sweep, it will disconnect from wifi and startup the wifi access point for config. The AP is named MCViser. The config page is found at 192.168.4.1.
STL files for 3Dprinting is updated with tabs to ease the placing of the background paper and correct position of top and bottom parts of enclosure.
