A new use and big software updates
A project log for PCB mill for under $10
pcb mill built from garbage using basic hand tools and little money
shlonkinshlonkin • 04/01/2014 at 14:35•0 Comments
It is always satisfying to find more uses for projects. I guess that's because so many of them just end up on a shelf collecting dust, not that that will likely happen to this tool.
I am working on a stargate for the sci-fi contest (shameless plug for our entry) and was faced with the task of carving lots of tiny details into thin, flat plastic. What an ideal task for this mill. I drew up some svg images of the stargate details and tried milling them into some 1.2mm polypropylene sheet. Here are some of the results.
It was a great success. It also led to several significant software changes listed below.
The updated code is in the usual places:
