After a little email exchange with Paul from pimoroni we agreed on me doing a small run of badges on @Tindie is alright with everyone, including their designer, so I will finally do a batch run with @oshpark for the first time.
The code has some potential, needs some cleaning up and some options for animations like I have added to my #K.I.T.T. - KNIGHT RIDER badge/brooch. I should use a higher value of resistors for the LEDs, they blink quite bright.
Part wise I'm all set, everything is ordered so I can sell them as kits, but might add soldered up options like I did with Kitt.
davedarko
Exciting! Please email support@oshpark.com if you'd like us to fully route out the individual boards (smooth edges, no "mousebites"). This is nice for kits. Or if you are using pick n place, we can panelize a mini panel for the configuration that you'd like. Thanks, Drew
will do so tomorrow :)
