I've been working on a ground station to receive LRPT images from the Russian meteor-m2 satellite for a while now. The scripts for automated recording, decode, and uploading are working reliably now so I thought I'd share.
All of this work is based on haslettj instructables guide, I modified his scripts to work with the tools below to receive and decode LRPT signals.
Tools:
In addition to the tools haslettj uses you'll need to get the following setup and working. Most are pretty self explanatory.
Reception and QPSK decode
I hacked up Otti's gnuRadio flow graphs to work from the command line for easier scheduling. There is a single input variable for the output file name. The output is a .s file which works with artlav's meteor_decoder tools.
You'll want to change the rtl=xxx string on line 52 to work with your rtl device ID.
This py needs gnuRadio 3.7 or newer installed, use your package manager.
Image decode
artlav's meteor_decode handles taking the captured qpsk data and turning it into a bitmap.
Uploader
i'm using prasmussen's gdrive tool to upload the decoded image to my google drive folder.
Scheduler
The github of my modified scripts is here. Create a soft link to schedule_all so that it runs as a cron task daily. You'll need to modify each of the scripts to work with your own home directory location. The qpsk decoder is dumping the received data into a file on a ramdisk. This is to lower latency and prevent gnuRadio from complaining about buffer overruns "OOOO".
Hello, i am from Germany and do´nt understand how to install the modified scripts. How to get the right Gnuradio Version? Do you have instructions to run this? It may make it easyer for me.
Really GREAT.
I was looking for something like this.
I will test it tomorrow.
Now i was saving Meteor IQ Files with rx_sdr and decoding after with SDR# and Plugins.
Now i will have a FULL Raspberry NOAA + Meteor receiver.
Ya man, sit back and let the machine do the work. It's nice to wake up in the morning and see your images from 4 am waiting for you!
