I just got an interesting mechanical probe, a Bard Site Rite - piezo at 7.5MHz. The plug is quite simple, and digging into the cable yields 2 pairs of cable, one coax, a bigger cable with two "big" cables. I've made sure it's a mechanical probe. The aim is to try and see if I can connect it to my board and get an image.
![](https://github.com/kelu124/echomods/raw/master/include/bard/images/IMG_20180317_202001.jpg)
Good point for this probe is that it unscrews nicely.
![](https://github.com/kelu124/echomods/raw/master/include/bard/images/IMG_20180317_202243.jpg)
and even better, it has changeable heads!
![](https://github.com/kelu124/echomods/raw/master/include/bard/images/pins.jpg)
I assume two pairs of cables are for motors / actuators, coax is for the signal coming back (hence the bead). But how can I see that on the pins above?
Going to search for the reference manual and other resources. I'd rather not unscrew the head yet!
To be continued... possibly with a corresponding patent... Electromagnets?
