Original sensor node
A project log for Wireless Temperature & Humidity Card
A credit card size Wireless Temperature & Humidity Node power by CR2032 Coin Cell
will-whangWill Whang • 01/06/2018 at 14:00•0 Comments
So recently I finally have sometime to write down some previous log.
This is my previous version sensor node, power by Arduino Uno with HDC1000 + BMP085 and Nrf24L01
to minimize the power, CR2032 is connected directly to system power, so I have to clock Uno down to 8Mhz, also you can see that I've added a jumper to disconnect Led after finish develop software.
By using sleep mode and optimize reading, I can reach 27uA at idle, and average 44.6uA.
