In March 2022, I designed a custom PCB for the controller board.
The PCB has the routing for 4 individual or continuous addressable RGB strips, 3 PWM mosfet control for white LEDs, 3 regulator placement.
The main benefit is the 2 push button that come nicely on the side of the base.
The same controller board goes onto the RingLight-Trio.
Stanislas Bertrand
