The project files are under version control and can be found on:
I found a 74HC294 programmable clock divider in my IC box. After reading the datasheet i liked to build a little box...
74hc294datasheet.pdfAdobe Portable Document Format - 301.26 kB - 12/07/2017 at 18:34 |
I learned that A6 and A7 cannot be used as digital IO (stands in the datasheet of the mega328, wow didn't see that..). So had to adjust the schematic.
The rest seems to work from POV hardware, so just a little bit of firmware needed and this little mini project is ready for the next step.
Also created a repository on github to handle the versions of the files (schematic and firmware).
So turning off the soldering station. LCD works, so i am starting to write the firmware for this puppy.
so made a rough schematic. Begin soldering...
Also inspect some parts:
Lets go!
Hi, your collaboration is clear and easy to understand. I like this Square wave generator because I would like to measure frequency from your previous video "High Frequency Counter" on https://www.ee-diary.com/2022/07/high-frequency-counter-with-arduino.html. Is that possible? How is the connection from this generator to High Ftequency Counter?
Thank you for your guidance.
Kamussu (Kamussuwanto@gmail.com)
However, I will use Arduino Uno.
