The 10 year old yapster's microphone finally died. It was strangely a broken ground to the microphone, somewhere in the cable & probably near the knot. Normally the thinner wire breaks.
Soldered into the speaker ground. Didn't do a good job insulating the solder joints but it worked.
The microphone arm is held on by a self tapper from the inside. Tightening the self tapper increases the friction. There's no spring or knurled surface. For animals wishing to add a microphone to normal headphones, it would entail something like this.
Using a directional microphone didn't work. It was too sensitive to wind. It has to be omnidirectional.
lion mclionhead
