Took a bit of wrestling with the mill, but I removed the table and lead screw. Wasn't completely necessary, but it made cleaning up the table surface a lot easier. Degreased everything, evapo-rusted the surface, then lightly stoned out the burs.
Also cleaned and stripped the mill body, and got it masked up for painting. Nearly done!
