I was trying to build a robot but did not like servos, I wanted smooth direct drive. This controller acts as a smart servo, it receives commands via RS-485, writes back angular position and can apply constant torque in when stalled or moving very slowly.
Lots and lots happened since my last post - I think I have done 5 or 10 versions before finally arriving at something that I'm (relatively) happy with.
Video first, then a couple of words.
The controller emerged as an attempt to build direct-drive robotic actuators. I did not like the complexity of the gearbox and wanted elegantly simple and smooth design. Well, it worked out very well. Unfortunately not strong enough to drive biped humanoid robot, but can be perfectly fine for other designs.
The controller measures position of the rotor via magnetic sensor and applies sinusoidal PWM at exactly +-90 deg at all times. This means that it applies constant torque in stall and close to stall situations, exactly is requires by robotics.
Size of the board was chosen to directly fit the back of BLDC camera gimbal motor which conveniently comes with magnet pre-installed. Other types or motors can be driven as long as magnet is mounted on the rotor and located close to sensor.
I'm trying to build a humanoid robot based on BLDC motors instead of steppers or servos and I'm designing my custom controller board. I'm facing this beginner problem: powerful motor de-stabilizes power supply for the controller. I will write up the project in details later, when I achieve some degree of success which can be shared, but right now I'm asking for help. Details about my design and the trouble I'm experiencing can be found here http://www.dizzy.ai/2017/12/08/interference. Any input on how to mitigate the problem will be highly appreciated!
Link provided explains problem in details. Here I will just give brief overview.
Maybe checkout the vesc? I don't know much about the subject but the vesc is open source
