PCB has arrived!
The nixie clock's main board that I ordered last time has arrived. (Delivery was faster than I thought ;D )
I ordered ceramic capacitors and several types of 3216 type resistors needed for PCB assembly.
Since the 0.1uF ceramic capacitors were rather expensive, I purchased tantalum capacitors instead.
Because the tantalum capacitors have polarity, I have to mark polarity with a marker pen on the PCB while checking the brd file.
LM2575 SMPS test
I hate the linear constant voltage IC very much ( For example, 78xx series)
They are difficult to deal with the heat issue. SMPS, however, generates little heat.
I made reference circuit of LM2575 5V.
It generates almost exactly 5V when 12V input is applied.
