My HV5622 serial-to-parallel converter's recommended operating voltage is 10.8v to 13.2v. I wanted to use 12V logic on it, but my MCU uses 5v logic. So I used a MOSFET-based level shifter(The circuit based on this site).
I tested the circuit in my breadboard. The 5v logic connected to the switch(Don't let a pin floating in logic low!) and the 12v logic connected to the multimeter.
That's great!
And I'm doing PCB design of my nixie clock's main board these days.
ho june
Forgive my ignorance but is this design bidirectional? Does a voltage on either side activate the opposite side?
