Is this a hardware project? A software project? IDK.
I had some problems getting the Algol CPU tests compiled and run:
I solved these problems by:
With these changes, I decided to record a complete set of the steps to get to this point in case I need to do it again.
First, create the VM and start it up:
mkdir xenial64
cd xenial64
vagrant init ubuntu/xenial64
Edit the Vagrantfile to increase the RAM size:
config.vm.provider "virtualbox" do |vb|
# Customize the amount of memory on the VM:
vb.memory = "4096"
end
vagrant up
vagrant ssh
On the VM, install an earlier version of the RISC-V compiler that was originally used to test this CPU:
sudo apt-get update sudo apt-get install autoconf automake autotools-dev curl libmpc-dev libmpfr-dev libgmp-dev gawk build-essential bison flex texinfo gperf sudo mkdir /opt/riscv sudo chown $USER /opt/riscv git clone https://github.com/riscv/riscv-gnu-toolchain cd riscv-gnu-toolchain git checkout f2a2c87 mkdir build; cd build ../configure --prefix=/opt/riscv make -j$(nproc) make distclean Edit ~/.profile to add: export RISCV="/opt/riscv" PATH="$RISCV/bin:$PATH" source ~/.profile
I modified my Algol repo to add the "env" directory I found in the "develop" branch into the "master" branch:
git clone https://github.com/xesscorp/algol git branch develop origin/develop git checkout develop -- Simulation/tests/riscv_test/env git commit -m "Added env directory needed for compiling tests." git push origin master
Install the Algol CPU repo on the VM:
git clone https://github.com/xesscorp/algol cd ~/algol
Install Python and MyHDL in order to simulate the CPU:
sudo apt-get install python-minimal python-pip sudo pip install myhdl
Finally, compile and run the Algol CPU tests:
./main compile_tests ./main core -a
That's it!
There are 115 tests in the suite: 96 passed and 19 failed. The failures were the timer instruction, the fence_i instruction, and all the atomic memory operation (amo*) instructions.
At this point, I have a (mostly) working simulation of the Algol CPU in MyHDL for me to start experimenting on.
On my Win7 machine, I created a linux VM to host the RISC-V toolchain:
$ mkdir xenial64 $ cd xenial64 $ vagrant init ubuntu/xenial64 $ vagrant up $ vagrant ssh
Then I built the toolchain on the VM:
$ sudo apt-get update $ git clone https://github.com/riscv/riscv-tools.git $ cd riscv-tools $ git submodule update --init --recursive $ sudo apt-get install autoconf automake autotools-dev curl device-tree-compiler libmpc-dev libmpfr-dev libgmp-dev gawk build-essential bison flex texinfo gperf libtool patchutils bc zlib1g-dev pkg-config $ export RISCV=/home/ubuntu/riscv $ export PATH=$PATH:/home/ubuntu/riscv/bin $ ./build.sh
Unfortunately, the build.sh failed. I tried some other linux distros (ubuntu/trusty64, debian/jessie64) without success: the toolchain failed to build for a variety of reasons. Finally, I edited the build.sh file to remove the build of the riscv-openocd tool. (I figured I wouldn't need the on-chip debugger right now.) After that, the build was successful.
The first step in this project was to clone Angel Terrone's Github repo for the Algol RISC-V CPU. Then I created a dependency graph for the MyHDL files that describe the processor:
In parallel with understanding the processor architecture, I have to get the software toolchain installed and running on a linux VM.
