This fluidizer project was built to powder coat small batches of black iron pipe fittings used primarily for making furniture kits.
As a small side business I partnered with a national custom furniture builder that builds farm tables and other rustic and rustic modern pieces. They recently wanted to expand into offering iron pipe furniture to their customers and online followers. Iron pipe furniture pieces are cool but if the fittings and piping that make them aren't finished properly they will rust over time and really start to look hideous...
Now there are a ton of ways to finish a simple plumbing fitting. A few of them actually look nice when done right, and even fewer of them actually hold up to time and abuse. In the end for my application, powder coating seemed to fit the bill perfectly.
Powder coating is such a unique finish because there are actually a few methods that the same bulk material can be applied for similar or in some cases a better quality of finish. Not to mention the literally thousands of colors and style options to choose from. - It defiantly rivals traditional painting methods. As with everything though, there are a few trade offs for each method and some barriers to entry that prevent most from exploring this finish.
Most everyone is aware of probably the most commonly practiced method of powder coating: Electrostatic Spraying. I won't get into detail of how this method works or the systems behind it simply because that is a little out of scope. The two largest barriers to entry though using this method is experience and cost with a few draw backs being part coverage limitations (Faraday cage effects) and setup time.
Experience plays a big roll into a flawless powder coat finish. When using the electrostatic spray method because the equipment behaves much like a traditional paint spray guy. An operator will have to watch their movements, the amount of powder being spraying out, how close they get to the part, etc. This takes time to master and can present a steep learning curve.
Cost is also an important consideration too. Typically, any decent powder coating system will run into the thousands of dollars. Recently there have been some half decent starter systems come available for $300 - $500 in the last 5 years or so but these are pretty much glorified toys. They work don't get me wrong! Of course, there will also be some people who are big supporters of them too. But for serious use, or if the goal is to powder small items or complicated parts this electrostatic spray method can just be a headache regardless of system.
As in my case, I was trying to coat a bunch of small pieces with the least amount of time and effort to keep costs as low as possible. Spray powder coating would have worked but it isn't really the best option because of coverage limitations. Electrostatic spray powder coating suffers from Faraday cage effects since the workpiece is grounded and the particle cloud is charged. When parts have corners, tight angles, close-proximity pieces, perforated materials, or embossed features it can be a real pain to achieve an even coat of powder.
The other method and the overall scope of this project is fluidized powder coating. It is less known that electrostatic spraying in that it is more specialized albeit simpler.
In fluidized powder coating, a hopper or a bed called a fluidizer is used to hold powdered material in a state of continuous fluidization by forcing air (or any gas) up through the powder material. A hot part is simply dunked into this fluid like material and pulled out several seconds later with a sugary like coating of powder to later be cured in an oven. (Or completely "flowed out" and "cured" if the part is heated to a higher temperature and has enough thermal mass.)
Small parts that have close angles, small openings, or perforated sections get a complete uniform(ish) coating of powder in just a few seconds unlike the electrostatic spray method. This happens because as the part is submerge into the fluidizer the once previously powdered material is behaving like a liquid covering every nook and cranny of the part. Additionally, since the part is hot (around 250 - 450 degrees f) the powder sticks to the part fairly evenly. After a short dip, the part can be removed and set aside for the next one.
Now the key to any fluidizer operation is a membrane or gas distribution source and gas flow rate. Simply drilling holes into pipe placed at the bottom of a container will work with most powders. However, the more homogeneous the distribution of gas the easier fluidization will occur. This project uses a membrane made of 30lb 25% cotton-linen paper. (This membrane happened to perform the best out of my various trials. Regular computer paper will work too!) The membrane of choice is suspended between two halves of a PVC union where air is supplied on one side of the union and the powder is paced on top of the membrane on the other side.
Overall, this fluidizer is constructed from a 4" PVC union. A few other various PVC fittings, a needle valve, and a wood base make it complete. I have created a component list and I hope to make a few technical drawings soon. The design is easily modified to go bigger or smaller and parts can be sourced from other suppliers. I already work closely with McMaster Carr with other business operations so it’s convenient for me to feature their parts in my designs.
Over the next few days/ weeks I will be updating the build logs as I have already made some cool modifications that increase performance and ease of operation! So be sure to check back if you’re interested!
Please send
me a PM or email if you have any questions.
Andrew Mayhall
