On last weekend: Just the Clock, Program Counter and some registers including ACC and B already implemented.
On the video bellow you can see the data transfer operation between registers ACC and B across the BUS happening manually for while. So, there is an "BUS Simulator" implemented for this (see half-size breadboard). (This video is in the Brazilian Portuguese language, but there is an English subtitle that you can activate on YouTube player).
Fábio Gil
